Results 1 to 9 of 9
Thread: p2173 issue on supercharged V6 challenger 2017
    greetings all
    we have this car tuned already a month ago and P2173 issue was major. Now, I have tuned it and this issue is still there but less happening. Still I want to fix it once and for all. The car is challenger V6 8speed 2018 with sprintex supercharger. As you all know, this code cause sudden engine switch off while driving.
    V6 chally sprintex.hptV6 chally sprintex.hpt
    Mar 2018
    Illinois
    873
    Not sure if this is your problem, but your peak airflow under engine diag/airflow (table ECM 14064) appear to be stock. I have seen them bumped up on other tunes (like in the one in the link below - also happens to be a FI 2017 3.6).
    https://forum.hptuners.com/attachmen...0&d=1540401867
    Also try enabling sensed MAP
    https://forum.hptuners.com/showthread.php?59236-P2173
    Quote Originally Posted by Homer View Post
    That table of the airflow was tuned but no results and I guess I need to max it out
    For the sensed MAP, can you guide me where can I find it?
    Best regards
    Mar 2018
    Illinois
    873
    Should be under airflow>general...top left corner where it says MAP.
    Last edited by Homer; 01-21-2019 at 04:13 PM. Reason: OMG, I said right when it is left...don't know WTF I was thinking.
    Should be under airflow>general...top right corner where it says MAP.
    Thx friend I will go back to it and let you know
    Sep 2020
    Did u figure out the problem? I have a sps sprintex supercharger on my 13 challenger, i am having this code come on a few times as i am slowing down to a stop, code p2173. I dont seem to have any leaks. I am also shutting down on WOT or a hard throttle push. Like i loose boost. We r still in the tuning stages.
    Quote Originally Posted by Thorv6 View Post
    try increasing the adapt under engine diag it has the same code
    Sep 2020
    Thanks for info, i just now seen u replied. I will talk to my tuner about this. I thought he had it fixed but it did it again, this time just cruising down the highway. So frustrating. Im also having issues with light throttle, like its not getting enough gas
    Nov 2019
    227
    Have you enabled sensed MAP?
