Hey guys my 2001 C5 with an LS3 and A&A T-Trim just got up and running...
Idle needs help.
B1 seems to be doing fine, but B2 is running rich. The ECM is trying to pull a lot of fuel from B2 when in closed loop but it still seems to be running terrible.
The B2 O2 sensor voltage does move, but it's not cycling like the B1 sensor is.
My wideband is installed in the B1 side and is reading 14-15ish... but that doesn't do me any good for bank 2.
I'll attach a log file (HPTunners).
You guys think the O2 sensor is bad or is B2 just getting way more fuel for some reason?
Maybe I should run it in open loop real quick and see if it still runs rough? (Might help indicate if the O2 is giving a false reading.)
Thanks!
