Having small problems trying to tune the following - LQ4, 42lb injectors @ 58psi, gt45 turbo, wastegate set to 12psi, 2 bar MAP sensor. I plan on putting 80lb injectors at some point. Still learning how to tune everything.
Got it to start and idle, but when I drop it into any gear it dies right out. wideband gauge shows its always running rich (11), but voltage for EGR shows otherwise. So I believe the wideband gauge is malfunctioning. I have the wideband wired into EGR so I can log that via HPtuners. According to HPtuners its not rich at idle.
I have tried logging and changing the VE table and adjusting the cell when its in gear, but it does nothing. I know the VE table is a mess, was just trying to get it to idle in Park and Drive, I don't think I was giving the correct data for the injectors (bought them 2nd hand). I adjusted the injector pulse until I got it to idle.
I attached a quick log and the tune, any tips on where to go from here?
