Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Wideband disappears when recording.
    Jan 2019
    10
    Okay all I have an issue. Im using an AEM 30-4110 Wideband sensor. I have the MPVI2 with the purchased pro feature and the prolink adapter. I have wired the wideband analogue signal into the Prolink analogue signal one. and I have grounded the sensor ground output to chassis ground.
    I went into the scanner and checked to make sure it was the latest update and I setup up the channel to the MPVI2.1 analogue signal. Then transformed the reading to AEM-4110. It shows up properly on the channel list, but when I go to record data the channel disappears I have nothing until I reload by saved channel list.
    What is happening here or should I say how can I fix this issue?
    I attached two photos showing the issue.
    Jan 2019
    10
    had to install the beta version of the vcm suite. 4.3... now the wideband reads correctly.
    Jan 2019
    dallas,tx
    2
    i am having the same issue, i purchased the wego iv,did the chart conversion for vcm to read right, and once i start recording it desappears.
    Jan 2019
    dallas,tx
    2
    and i did just buy the mpv 12 pro, with the laptop from the tuning school, so im asuming its propperly updated. thanks in advance
    Same issue here.. It was working literally last week, now all of a sudden it disappears when I hit record
    If I log interface input 1, I get the correct corresponding voltage - but the EQ Ratio output for Innovate wideband disappears
    Anyone ever fix this issue? I made sure my software was up to date, still getting the disappearing wideband
    I solved this issue, it was 100% my fault.
    I'm guessing I deleted the PID, and when I re-added it, I did not do it the correct way. I had to transform the INPUT 1 input, now it is working
    Dec 2008
    34
    I am having a similar problem; however, the channel does not disappear. I do not get a reading tho. I have transformed it and followed instructions. mpvi2 pro with aem WB.
    Apr 2015
    6
    I am having the same problem as flash13 but using a different wb. Have tried everything with no success.i have a ticket in just waiting to hear back.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,239
    I would recommend updating to the newest 4.3 beta software & resyncing your interface, no reason that shouldn't fix it assuming you have the pro feature set.
    Apr 2015
    6
    I have pro feature set and I am using the newest beta with many resyncs
    Aug 2017
    3
    I'm having this same issue this week. I will try the beta and see what happens.
    Aug 2017
    3
    I tried the beta and resynced, but I'm having the same issues. Anyone have luck with this?
    Nov 2018
    2
    like this is ridiclous this is the only problem ive had ive done it all transformed updated all of it and it still disappears on me too
    Potential Tuner ironchally's Avatar
    Sep 2018
    6
    Same here, tried everything everyone suggested. Still no good, please help
    Jun 2010
    559
    Who figure this out?? Having problems it disappears.
    Now what wideband works with the mpvi2 and can I just joint the wires no need for a cab buse? I have a ballenger afr500.
    Aug 2018
    9
    Same issue here aem 30-4110 hit record it dissapear everytime
    Jul 2018
    2
    Same problem here using AEM 30-0300 on 4.4.4 (Windows 10). Once the channel is setup it will disappear when the log starts. I have tried to resync multiple times with beta and 4.4.4. The odd part is I got it to work on another laptop running Windows 10 on 4.4.4. The problem still occurred... however, after a resync (unplugged from obd) it was up and running.
    Jun 2010
    559
    Quote Originally Posted by Cobb420 View Post
    What’s the resync for? I have a new mpvi2 not using the old mpvi or never use it on this laptop.
    May 2018
    27
    The Scanner software does the transformation to AFR in the table, but charts the raw input without transformation. I believe if you create a math pid to do the transformation and then chart that pid, it will chart correctly.
    Reported this problem months ago and never received any acknowledgement or fix.
