So I have been playing around quite a bit and finally landed on a tune that works very well. Can you guys take a look and see what you think? I mainly use the truck for hauling a heavy truck camper and a couple dirt bikes. I am usually around the 10000 ft altitude range. I am getting decent power from this, but could stand to have a little more in the mid range and maybe some quicker spool up. Trying to keep smoke and rattle out. Currently I have zero rattle.
Thanks.
2004.5 Cummins. Exergy bms 50hp injectors. BW300sxe turbo, BD T4 manifold, BD CAI, 5" turbo back exhaust, turbosmart ext wastegate, BD lift pump with 2 mic filter and h2o separator, banks intercooler, Banks intake horn, slightly built tranny.......
Can try adding a little bit of main pulse width in the areas you are wanting a little more power and bump timing up a little bit at a time where you are wanting a little more power. If it hinders spool up drop timing back a bit. Upper end power few things, your pedal map commands more than any limiter will allow at full throttle, raise limiters in areas to allow what your throttle map can command, fatten up rail pressure in the upper end, bit of a bump of pulse width and timing. It?ll be a fine balance between everything
