I wanted to ask to make sure I was reading this right.
If I have a turbine RPM of 1600 and engine torque of 286 Nm, in the attached table you would expect to see a desired TCC slip of 0 RPM with the AC off.
You can see the log screen shot shows 10% desired, 4.8% actual. Not sure why 10% is desired.
I will look around to see if there is anything else that may limit or add, adaptive min is set to 110 Nm and max 40 Nm (default values in my calibration) so it seems like TCC adapt is disabled - or I would have thought it may be some adaptive variation.
