Results 1 to 8 of 8
Thread: issue in WOT the PE TPS not stable
    May 2017
    6
    Hi every one,
    i have 6.0 2008 taken from savana swapped in nissan Patrol Manual trans
    the ecm is that came with engine
    i have issue when i go WOT (full push pedal), the PE TPS is going unstable around 4000 RPM and that affecte the commanded AFR.
    please if you can help me out in this
    13,559
    Did the throttle body and pedal assembly come from the same vehicle too?
    May 2017
    6
    the Throttle body come from the same vehicle but the pedal taken from caprice Holden 2010 v8
    also already change the plug wire to fit the new pedal.
    May 2017
    6
    waiting for your help dears
    May 2017
    6
    +UP
    May 2017
    6
    Guys i try with pedal that came from same car that i took the engine and ecm from it and still facing same issue
    please can anyone advise me here
    Nov 2017
    Australia
    119
    Have you finished the swapping process?....no readings for oil pressure, oil temp, VSS....
    The MAF reading is very unstable during the video and 4000rpm is typically where Dynamic drops out and runs on MAF only. Is the intake setup to provide smooth[ish] airflow for the MAF?.
    Do you have all your wiring and ECM earths (especially engine block) sorted?.
    The tune file might be helpful, too.
    Ian B
    '15 Holden VF SSVR L77(gone), '19 Ford Ranger PX3 3.2TD, '22 Toyota GDJ150
    May 2017
    6
    thank VFL77 for your reply
    i solved the problem when i change some fields highlighted by green as below
