Results 1 to 12 of 12
Thread: What afr meters are you guys using?
    Nov 2018
    47
    What afr meters do you guys like? I?ve seen the on hptuners sells, the innovative lm2 and the Daytona set up the Tunning school sells. I?ve also seen the aem but I?m probably going to be dealing with a lot of pre can bus vehicles. Is there any difference in quality of these meters?
    13,557
    Do some searching I'm sure you'll find lots of threads about this.
    Almost all of them use the same 4.9LSU sensor now so it's all about looks and preference. The AEM's are hard to beat for how easy they are to use and setup.
    Nov 2018
    47
    Ok cool, so as long as they?re all good quality is the main thing I?m looking at. I can figure out setup. Thank you for your input.
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    605
    After using and complaining about Innovative LC-1s for years, I switched to https://www.14point7.com/products/sp...a-controller-2 and haven't looked back. Dead on when tested with test gas, and never needs calibrating. JMHO.
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
    Jul 2010
    Olympia, WA
    24
    For a consumer grade meter the Ballenger AFR500 v2 is an excellent choice.
    https://www.bmotorsports.com/shop/pr...oducts_id/2337
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    I just bought the PLX. Havent hooked it up yet, but am planning to use it's simulated narrow band out so I don't have to weld a new bung into the exhaust. For now exhaust is stock and there is zero room on the 06 GTO to add another O2 sensor pre-cat on either bank
    Oct 2017
    Boston
    75
    I switched from Daytona to AEM's. Had nothing but trouble with Daytona. AEM's great and has an analog output for AFR and boost.
    Jul 2018
    Texas
    214
    AEM. Can't go wrong. Simple hook-up and set-up.
    Feb 2023
    5
    Quote Originally Posted by Billf6531 View Post
    I am looking at running their spartan 3 setup and jrp gauges, still happy with them?
    Jan 2004
    605
    Absolutely. When I bought it, I was anxious due the the poor performance of the LC-1, so I called Alan (the developer) and question him regarding accuracy. He said he would test the 2 units he would send me with test gas, and supply the test result. The performance on the worst unit was .003% error. Can't improve on that, especially with no calibration required, and very inexpensive as well.
    Best regards,
    Bill
    Aug 2023
    1
    Can the spartan unit be connected to the mpvi3 for data logging?
    Jan 2004
    605
    Quote Originally Posted by kowclub173 View Post
    Yes, with the Prolink+ adapter.
    Best regards,
    Bill
