Results 1 to 6 of 6
Thread: 6L programming, how do you enable a second shift table like $l60e tow/haul mode?
    Baltimore, Md
    1,208
    On the Camaro/Vette/CTSV for example
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Apr 2016
    331
    The cars with a 6L usually have a manual tap up/down mode, but it is controlled through the BCM and communicated to the ECM, then to the internal TCM. Trucks with tow/haul do the same. Do you have a BCM installed?
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Sport mode, I think it's pattern A. To test, set pattern A shift speed table to 100 MPH, put the car in sport mode. If the trans won't upshift, you're using pattern A.
    Russ Kemp
    Jul 2018
    Texas
    214
    I chose a 2010 Chev Silverado diagram to show you how the tow haul mode and tap up/tap down is wired. Don't know if it will help. Maybe you can incorporate into your tune if the table exists and trigger and second shift chart. Like NotSure stated a BCM would be needed and be compatible with the ECM/TCM to supply the data.
    Baltimore, Md
    1,208
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Ok so the CTSV, camaro, vette, g8 all have sport shift setting Im pretty sure. We cant datalog to see what pattern its currently in? Could figure it the way your saying if need be.
    If I want to START in say 3rd gear for example then shift 4th and 5th normally automatically, set 1-2 shifts all the 0 mph, then 2-3 shifts all to 0mph should work yes?
    Australia
    119
    Quote Originally Posted by GrannySShifting View Post
    Scan for TRANS SHIFT MODE. It'll come up with things like Normal, Pattern A(cruise), Pattern B(sport) and TUTD.
    NB: 4.0.12 of HPT is missing this channel, but 4.2.1 is ok.
    Ian B
    '15 Holden VF SSVR L77(gone), '19 Ford Ranger PX3 3.2TD, '22 Toyota GDJ150
