Sooo i am completely new to any tuning and will definitely sound like a idiot.
ok i am running a e38 pcm on a ls3.
standalone loom and powerglide.
computer was running a tr6060 manual prior to this.
Engine specs are standard bottom end with gapped rings for boost.
ported heads and upgraded valve springs,
injectors are standard decapped,
2.5bar map,
s480 turbo.
fuel large intank pump to surge to twin 044s to a filter then fuel reg on 58psi pressure.
now for the life of me can i get this thing to even idle. i adjusted injectors to flow 88lb hr and that made it even worse so i set back to standard and now it will fire for 2sec. i have also turned off vats. also running SD and have roughly adjusted the ve and timing.
please if you have any experience and time on the weekend to have a look at my tunes and help with anything would be appreciated first is complete stock and second is my adjusted tune.
it feels like something is shutting off soon as it begins to idler.
do i need to ground park/neutral? or change somthing in the tune because powerglide?
i have researched everywhere with no further information.
