Results 1 to 7 of 7
Thread: Hellcrate Programming, VIN Question
    Oct 2017
    30
    I have a hellcrate motor with the hellcrate PCM.
    I see that the hellcrate is a supported motor and requires to 2 credit to program.
    My question is how do you get it to recognize the PCM if the PCM doesn?t have a VIN?. Or how did you write the VIN?
    You should try read the pcm first. I it reads the file you should be able to make changes. You will not need credits until you are ready to write the tune file.
    Mar 2018
    Illinois
    873
    I thought that is only true if using an MPVI2 as I remember with the MPVI1 you could not save changes to read files without credits.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    Our software uses several different ingredients in order to determine the ecm type and allow for automatic reading. The vin is just one of several things our software looks for.
    Oct 2017
    30
    Thank you
    Apr 2019
    10
    Were you ever able to tune your engine? I chose gpec2a but i cant write to mine. It give me controller init fail code when i try....
    Oct 2017
    30
    Quote Originally Posted by karr View Post
    Sent you a PM
