Originally Posted by
murfie
Load is determined by MAF and fuel trims.
Load determines indicated Torque from the model. The model assumes MBT and stoic fuel.
From actual spark and fuel, actual engine brake torque is estimated.
MAF goes into TB model. This works as a feed forward to correct desired load. The DD table is used to determine torque request. This is how your desired torque and desired load relationship is established.
You need to get DD table and TB model torque/load request closer to your engine brake torque and actual load. Determine if you think it's TB model, DD table, or torque tables. It could also just be your MBT spark tables relationship to your borderline tables making the ECU estimate engine torque wrong.
