Results 1 to 3 of 3
Thread: LTFT STFT reset question.
    Sep 2017
    montreal
    58
    Question LTFT STFT reset question.
    hello everyone.
    after write vcm(change injector flow rate,) do i have to reset LTFT STFT Fuel trim?
    13,576
    If you are using the trims to tune with, then yes you need to.
    You'll likely want to use a wideband o2 sensor though to check up on the airflow model because of the injector change.
    Sep 2017
    montreal
    58
    thanks
