2007 Charger SRT8 P061A Limp/High Idle after prolonged idle time.
Hello - Have one that is throwing me for a loop.
Details: 2007 Charger SRT8, Intertia Motorsports SRT Max Plus cam, cold air intake, hogged out cats, cat back exhaust.
Car otherwise runs fine. However, when you let it idle for periods ranging from 5-25 minutes it will go into limp mode and the only code it will display is P061A. Fuel trims are sub +/- five to ten percent at all times. Made good power on the dyno and otherwise generally runs just fine.
I've tried turning the code off, however, that doesn't change the problem. I will post up the log and a tune file later when I get some time. Does anyone have any thoughts? Tips? Tricks?
did you fix the problem am have the same issue
Maybe your Airflow Model isnt right.
So load will not be correct after cam swap....
