Yeah, Ive got 4.2.12 and it wont either. I requested something different, we'll see what comes.
Try this: wrote entire.hpt
5FDP- The same from PT.NET? Were you able to open the last file?
I haven't looked at anything yet.
I can open the latest posted tune. It is set up for 2 bar with the boost in the VE. Make sure you have the map sensor that you listed in the first post. The offset for the correct sensor is 8.00. Even leaving it at 10.33 will not make a lot of difference in KOEO. Sounds like the wrong sensor is installed. Read the number off the one you have installed. The VE table is kind of a starter table, you will need to do some smooth driving and collect data and correct the Primary ve table. Looking at the 105kpa row in the primary ve, and looking at the 105kpa row in the boost ve table---the boost 105 row should be the same as the primary 105 row for a smooth transition into boost. This is after you get your primary ve table corrected because that row is going to change. Just for grins, look at the boost table in 3 d view, then change that one row to the primary 105 numbers, save it and look at it again in 3d. You will have a big cliff. Don't forget to change the IVT Terms to 3.96 across.
2013 Silverado 5.3, 6L80k 8.8
I verified the 12615136 and fired the truck up with the new tune. It actually started and idled cold better than before but I haven't had a chance to log or drive it yet. Would I be right to change the offset of the sensor to 8.00? They apologized about the initial tune and told me to log / send it back so they could clean it up. I'm glad this is a weekend toy and not my daily. Thanks again for the help.
First run out. first run (1).hpl
You don't "need" to change the offset to 8.00 from 10.33. It will make very little difference. It's just getting everything right so you know your tune is the best you can get it. Your low rpm STFT's look pretty good. I don't see a wideband for that wot??? You need to log injector duty% and cylinder airmass.
I don't understand why you are showing 101kpa koeo and only 104kpa at wot----something is screwy.
Doesn't make sense to me either. And why does the gauge max at 110kpa when set up for 2bar?
Try removing the current MAP sensor channel, then re-poll for supported parameters while hooked up to the vehicle and add back in the MAP sae channel.
Gotcha. I?ll update my channels and layout today.
