While I was doing my SC install I had to swap out my MAP sensor to a 3 BAR and scale it. However there is also some MAP adjustments under Torque Model--------General--------Torque Calculation. I have not done anything to the tables but they are very close to my factory MAP ranges before I swapped to a 3BAR. Is this something that needs to be matched to my new sensor. It says they are a Torque Calculation so I'm not sure if they merely are a means of calculating torque as a "read only" OR something as a scalar that will make a difference.
Thoughts??
