I did a log starting from cold to warm and my rpm slowly rose to around 1000 rpm, and then somewhat settled down but not to what I was commanding. I have my base idle set to 825 once temps reach 111. At around 111 I'm idling around 950 to 1000. It had been doing fine in the past but started doing this recently. I don't think it could be a vacuum leak because it slowly rises with temps.
For my air fuel problem. I recently enabled my STFT openloop. I'm commanding 1.0 EQ across the board for simplicity. My STFT is about -10. My wideband bounces between two cells. 14.0 and 14.28. I might be looking at this wrong, but my narrowbands say I'm 10% off and my wideband says I'm -2 to -4% off. Not sure what is correct. Also in my tune I have 14.68 for stoich. In my scanner for some reason not sure if it was a default setting or the way I set it up but my Air Fuel Commanded (Lo Res) is at 14.600. Could this be my problem? I've tried to change this but unable to figure out how.
Scan. 2519.hpl
Tune. hhhhh.hpl
