Results 1 to 5 of 5
Thread: Controller init: Failed 2013 6.4l cherokee
    Jun 2010
    293
    Working on a 2014 jk, hellcat engine, 2013 6.4L cherokee ECM, i can read the file, licensed it, modified the file, but cant flash? CONTROLLER INIT: FAILED, it can read/write TCM tho. This is the second ECM, got it brand new, got a base tune but cant flash it either, both says same error; CONTROLLER INIT: FAILED
    , i got the second ecm, as the first one was used and tought was flashed with other software or something but it was not the case, really need to fix this.
    attached is the file i read from it, licensed it, and tried to flash but no luck.
    What year is the pcm. Is it from a newer year???
    Jun 2010
    293
    Quote Originally Posted by Jailhousecustoms112 View Post
    I ordered it at dealer for a 2013 grand cherokee 6.4L, sent it to get a base tune, it reads correctly but cant flash.
    Jul 2015
    925
    if you haven't you need to start a ticket with HPT Support.
    Mar 2018
    27
    Did you ever resolve this issue? I am having the same thing happening on a 2014 6.4 WK2. Submitted support ticket but having difficulty there as well.
