I think I remember reading somewhere that the early OBD2 Camaro's were dropping Bricks. So now I have a client with one and it reads Brickable for the Write Calibration. So I have to Questions:
1. Can I go to the P01 PCM and simply "Write Entire" and still retain all the factory body controls so the A/C and all that still work? or Would I need a dealer to load the tune, then reflash and rebuild my tune?
2. What makes this PCM so Brickable? I am curious because I have a benchforce powerblock from EFI Connection. If I had to I could directly flash the PCM every Time, in order to bypass the car's internal wiring if thats the problem. Or is the PCM just a brick straight-up???
