Results 1 to 6 of 6
Thread: ? on PCM/TCM writes
    Feb 2006
    PAC NWest
    396
    ? on PCM/TCM writes
    The NGC3 controller is a separate PCM and TCM. But when you do a read it creates a single HPT file.
    When you do a write the PCM and TCM are listed separately and the PCM has a Write Calibration option while the TCM only has a Write Entire option.
    If I make changes to the trans tables, do I need to do a TCM full write or will a PCM Write Calibration do the job?
    Feb 2006
    PAC NWest
    396
    Anyone?
    28,263
    your question is quite unclear.
    If you just want to flash the tcm, flash the tcm(assuming this feature is available for your application). The drop down box will give you all the options available. Writing the pcm writes the pcm, writing the tcm writes the tcm.
    Feb 2006
    PAC NWest
    396
    The fact that a Read results in a single file is what has me confused. If I make changes to the timing and to the trans, will a Write Calibration to the PCM also write the Trans changes?
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    Quote Originally Posted by gottogo View Post
    No, if you make changes to PCM parameters, you need to write the PCM in order for the changes to take effect. If you make changes to trans parameters, you need to write the TCM. If you make changes to both, you need to write both.
    Feb 2006
    PAC NWest
    396
    That's the info I was looking for. Thanks.
