Thread: Multiple Interfaces and User Defined Parameters
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    questions
    trying to get a general concept of how to use modded OS via User Defined Parameters with multiple interfaces.
    I deal with multiple shops, vendors, individuals with their own interface. As well as having multiple interfaces myself.
    Q.1
    MPV1 and MPV2 both require a License @ $169.99
    Q.2
    if one person owns both MPV1 and MPV2 interfaces on a single account is a single license interchangeable and usable with multiple interfaces?
    Q.3
    is the license attached to the editors file/save function or the file/write function?
    if licensed interface makes a change to an OS / ECU can that ecu or file be used and loaded by a non licensed interface?
    thanks
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    Mar 2006
    sunny So Cal
    292
    ??..bump..??
    NotoriouSS TAD
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Q1, yes both are same price, not dependant on cable
    q2. No it wont work on both cables, if only licensed to one
    q3. My best advice is pay for it on the 2(has the widest array of vehicle support), then always use that when looking at ud parameters
    i have it on an older cable, but is useless on non supported vehicles. If your gonna pay, do it on the two. You just have to use it each time
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    28,285
    Yup, and keep in mind MPVI2 allows you to save files without having a license for it so having the user defined params on just the MPVI2 will be more than enough.
