Results 1 to 5 of 5
Thread: MISFIRES Tab / Table ?
    Tuner in Training Y2kHawk005's Avatar
    Oct 2018
    Austin, Tx
    37
    I have version 4.2.12 MPVI 1 Pro and an LS 408 large cam engine build. The only work around I have at this point it to alter the MISFIRES table as stated on the HP Tuning School's site. The path I know to take is Engine Diagnostics and then the tabs for Misfires, DTCs should appear. I do not have the MISFIRES tab. Can someone share if they can see this MISFIRES table and if I'm missing something then please share as well.
    I did contact support via email and have a trouble ticket currently in the system.
    Thanks,
    Jim
    13,559
    Is the view set to advanced under the edit tab?
    Oct 2018
    Austin, Tx
    37
    Holy Crap!!!!!! It was set to basic, I changed it and now the tabs appeared. Thanks!!!! A newbie with a big project, but getting closer each and every day.
    Oct 2018
    Austin, Tx
    37
    My saga continues! Made the changes in the Misfires - Car starts, runs better - sounds better but still getting the P0200 Open Injector Loop. Can't tune with this injector open loop problem. Looking into ECM replacement at this time....Any other suggestions - greatly appreciated.
    Oct 2018
    Austin, Tx
    37
    Here is a quick update: Still had my suspicions about Injector #8, I NOID light tested and it failed. No light at all. Voltage tested Inj #8 power circuit and to my surprise: read 12 volts. Looking into the drivers next.....
