Results 1 to 11 of 11
Thread: e85 on 2014 gt ????
    Jan 2019
    14
    e85 on 2014 gt ????
    had a quick question on updating a 2014 5.0 gt to e85, so I haven't messed a whole lot with fords and wondering if anyone can assist a bit
    on adding 47lb injectors and going e85??
    been doing some research but id just want to get some input from you guys as well. car is stock just wanting to update it a bit.
    Sep 2010
    821
    there is a thread devoted to flex fuel tuning with files you can use to help guide you, search bar is on the top left of the forum
    Jan 2019
    14
    Thanks man gonna give that a shot
    Apr 2018
    219
    Quote Originally Posted by Jn2 View Post
    Top left?
    Jul 2017
    314
    I did this on a 2014 GT, no power at all on dyno, we put it back on gasoline.
    25,865
    Quote Originally Posted by MRRPMBRP View Post
    Same timing? Typically decent gains can be found by shoving in more timing on a vehicle running E85.
    Jul 2017
    314
    We tried different timing, dialed fuel in, nothing. On motors that aren't knock limited, e85 doesn't help power. I may could see some slight power on hot days or something, from a lower iat, though, here, on that day, nothing, not worth the hassle.
    Apr 2018
    219
    The highest I've seen with this gas around here is 26.5 degrees. I hooked up to my friends 07 silverado and his ethanol pid said 3%. I guess that would explain it? Can I enable flex fuel just to get the ethanol content channel?
    Dec 2017
    45
    No our cars don’t have an ethanol sensor. Only way to tell is by lambda.
    Also to make the switch first change stoich AFR. I have mine at 8.85 and then depending on mode goto MAF and add 30-50% fueling. Drive and adjust as needed then you can start playing with timing. Gains on E85 N/A cars usually shine under the curve as you can ram more timing down low for that extra grunt off the line.
    Sep 2008
    31
    Meh, customers think E85 in their basic bolt Coyote makes it magically more powerful, so I give them what they ask for. I'm sick and tired of having to explain it to them.
    MRRPMBRP is just confirming what a lot of us already knew.
    Most all NA Coyotes hit the peak gains from timing advance before they hit the knock limit of 93 octane.
    As hard as it is to find reliable E85 sources, I try to "encourage" my clients not to waste their time. If they really want it badly, I'll recommend a flex fuel tune if they are NA.
    As for the boosted cars, I recommend E85 and a 93 tune so they can switch back and forth. Boost + E85 + Timing = win
    2013 Mustang GT - Twin Turbo
    2016 Mustang GT
    2011 Suburban Z71 - Tow Machine
    Jul 2017
    314
    Quote Originally Posted by Dan Stewart View Post
    Yep, maybe a little E85 laced with nitro would help power.
    Or maybe a 15:1 compression motor.
