Results 1 to 5 of 5
Thread: 2017 vs 2018 f150 advance rate
    Apr 2013
    206
    I was comparing the 2017 ford f150 5.0 Max advance rate for the exhaust cam is 172 degrees vs 250 degrees for the 2018
    the IVO is also changed from 239 degrees for the 17, and 620 degrees for the 18.
    Any idea as to why? Different camshafts?
    thanks guys
    Advanced Tuner veeefour's Avatar
    Oct 2016
    Poland
    758
    What engine? Coyote? If so then yes - different cams and different cam timing as well.
    Regarding Mustang : it seems that Ford went with 360 degrees more separation between banks with gen 2 compared to gen 1. However in gen 3 they went back with timing similar to gen 1. Not sure why tho.
    What's going on with F150 tho...only Ford knows...
    Apr 2013
    206
    yes, the post mentions "5.0" not sure if theres another engine with that displacement other than the coyote.
    I dont care about the mustang as of right now, just the f150. 360 degrees more separation? that doesn't sound right. Is it possible that they are referencing a different valve event, i.e. IVC OR IVO, or maybe EVC OR EVO? that is a big swing in degree.
    Oct 2016
    Poland
    758
    No, not the lobe separation, bank to bank separation...
    1st gen - 1 crank rpm/360' covers the both banks valvetrain
    2nd gen - 2 crank rpm's/720' covers the both banks valvetrain
    3rd gen - same as 1st gen
    That's why you see a difference in tunes - which isn't something you cannot change.
    Apr 2018
    386
    Can someone explain what this topic is about and how it relates to differences between a gen 1, 2, 3 coyote?
    Does this have to do with balancing the valve trains on each side of the engine? I tried to google it but it keeps showing stuff about 'banks' LOL.
