Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Insufficient Fuel Flow 2019 mustang GT
    Jul 2017
    377
    Quote Originally Posted by Bill88stang View Post
    Mine originally tune that was done for me before I started to learn on my own all the dd tables were bumped up quite a bit, I?ve seen several tunes where they were all left alone. What?s the proper way to modify them? Modify the whole table or just the wot portion?
    Off subject, but on mine, seems the larger tb I go with, the more they need adjusting for drivibility, down low speed.
    Wot doesn't matter, since it transitions to wot before the table gets there.
    Usually DD changes trigger that limit from what I can tell.
    +1, still cant figure out why though
    Jan 2013
    Hawaii
    1,443
    I've always seen this when the SD was limited in calculating the MAP. The injector data relies on the calculated MAP and inferred rail pressure to determine how much the injectors are flowing. if you hit the pumps max duty cycle, not likely in the return style system if you have it set up correctly, or the MAP hits a limit you will get an insufficient fuel flow condition.
    "We can never be right, we can only be sure that we are wrong"- feynman
    Sep 2014
    Any updates on the issue? Im curious
    Oct 2009
    7
    In my 2019gt the DI injector is limited to i believe .90 in the injector data area. With my car set to .90 i hit Injector limit on E85. I raised the limit to 1.6 when max is 2.0 and i have not hit limit since.
