I created a configuration that is different from the default. The chart shows it correctly but the Table Dispplay shows the default entries. OK so I figure I hit the default button by mistake. I can delete the entries in the table display but the PID dialog box shows in red the PIDs I want to enter. Therefore it will not take them as though the item is already been selected. It was but the table display only shows the default enteries. However the chart display is showing the correct ones??????
I restart and loaded several times. It just will not display the selected PIDs and will not let me rebuild the table either.
Any clues to what I did wrong. Also anyway to get the table display PID to also go in the chart at the same time?
TIA,
Rob
