H
just trying to understand and say hello into the tuning world to continue to learn as much as i can
H
attempting to upload my current tune and log previous to me changing injector flow.if the log post you will see that during the log the long term fuel trims already have a Lean Condition they are trying to complensate for(if my mentality towards that is correct)
trying to upload a log and tune hope this works..
What you want to do with the injectors is to put in the correct data for whatever injectors that you have installed. Look at the make and part number and then look up the correct data for them. The 41# across is for a return style fuel system.
2013 Silverado 5.3, 6L80k 8.8
Never change the flow rate like that. If the injectors are stock, leave the data alone.
Injector settings are set and forget table.
If the trims are not where you want them you need to calibrate the airflow model to bring fueling in line. Either use a wideband o2 sensor or a special fuel trim graph to fix the MAF/VVE. Though you need a wideband to do any wide open throttle tuning because it doesn't use o2 sensors in open loop.
ill change it back and show a log for the morning and afternoon commutes tomorrow.
Hey DCScorpoG8, do I know you? This is James with the Silver G8
Daily Driver= 2003 BMW 330xi
Weekend Cruiser= 2009 Pontiac G8 GT (Vararam, TSP LS3 N/A Stage 1, OBX, CTS-V converter, MagnaFlows w/ J-Pipes, 160 t-stat)
Project Car= 1991 Chevrolet Camaro RS (LQ4 w/ Gen 4 Rods, LS3 heads, turbo...)
Truck= 2007 Chevy Silverado 1500 LT LY5 4x4
yep its me.. whats up.. im on here trying to get my knowledge up.. i thought abou tasking you to come check my tune out.. let me know im about to upload what i just reverted on my tune. hit me on messenger
i put it back to what it was stock when i uploaded the first tune
