59. race 10.13.hpl58. Current on 10.13 using MAF.hpt38. maf driving around 9.23.hpl39. lean at startup 9.24.hpl44. ve 1 9.26.hpl45. ve after scan 1 9.26.hpt48. ve 3 9.26.hpl49. ve after scan 3 9.26 current.hpt
Looking for a little help dialing in the tune on my cammed LS3 with a T56. I'm running a 0411 PCM and started with a 02 LS1 base stock tune. I'm also running stock ls3 injectors and the cam is 231/244 112 +4 with .600/.600 lift. I've read multiple How-To's a multiple times but I'm having some issues really dialing it in. Note that my injector data came from a couple documents I found on here I believe. I'm running a AEM wideband in the driver's header. It was right after the header but I swapped it with the O2 sensor incase a small leak was causing some issues. He's the breakdown of what I'm having issues with.
Car running decent
I warm it up and start reading AFR error (btw I've had this issue tuning VE and MAF)
After driving around going 50-75mph for awhile I'll pull over and update my table
Right after I start back up it runs way lean at low RPM and starts bucking like crazy but after you start driving those cells turn from +20s to +4s or so on the interstate.
My thought was this was because of my IAT so I purchased the "faster" sensor moved it around and now even to outside my car. I seems to have slightly helped but it still seems to act weird.
Also it seems like no matter what I do I can't get within that 1-2% error across the board. I've multiplied by half and have even only copied sections, but it seems like I always overshoot and go lean.
So basically what could I be doing wrong or what's wrong with my tune/car? Maybe I just need to keep at it with the IAT sensor outside of the engine bay until I get the intake rerouted to be a true cold air?
I attached some files but they may be hard to follow so let me know if I need to clarify. 1 would be the oldest and 60 would be the most recent.
