Does HP Tuner Reset Alcohol %? Im Working With An Impala
I couldn't get it to work the last time I looked for it on a silverado.
I ended up using a snap on modis to reset the fuel composition.
I Did the Same,This Was An Impala
Just reset Fuel Trim,Going To Fill Tank,This Is A Silverado.Then Recheck!
Alcohol % went From 8% To 7.1% After Fill up Confirming HP Tuners Does Not Reset % To Zero.While Other Scanners
Will!
Has there been an update to the scanner software to allow the reset of the calculated alcohol content?
