Results 1 to 5 of 5
Thread: Reset Alcohol %
    Dec 2015
    3
    Reset Alcohol %
    Does HP Tuner Reset Alcohol %? Im Working With An Impala
    13,533
    I couldn't get it to work the last time I looked for it on a silverado.
    I ended up using a snap on modis to reset the fuel composition.
    Dec 2015
    3
    I Did the Same,This Was An Impala
    Just reset Fuel Trim,Going To Fill Tank,This Is A Silverado.Then Recheck!
    Dec 2015
    3
    Alcohol % went From 8% To 7.1% After Fill up Confirming HP Tuners Does Not Reset % To Zero.While Other Scanners
    Will!
    Jun 2021
    6
    Has there been an update to the scanner software to allow the reset of the calculated alcohol content?
