So I cam swapped an LS3 with an LSA blower on it. I'm having some issues getting the idle to play nice. The cam isn't very wild (223/231, .629"/.629", 115 LSA, 112 ICL), just a small blower cam.
If I lower the final idle airflow tables (10-10.5g/s) it seems to oscillate and die on occasion but other times run fine. If I raise it to around 11-12 range the idle sky rockets to 1-1.5k in neutral but in drive it seems great.
The idle timing was at 13 I just raised it to 18 and I'm going to try 10g/s on the final idle airflow table.
Any other tricks to smooth out the idle and keep it running?
