I have a new project in old Nissan patrol and I found someone with the project :
LS2 6.0 holden commodore 2008 e38 ecu ( i swaped the wires to be suitable for nissan )
https://www.ls2.com/forums/showthrea...Pinout!!!-Help!!!!!!
I followed all the wiring and all the instructions but I faced the MAF sensor problem P0102 fault ( not working ) . I searched to fix it and I found this website :
https://ls1tech.com/forums/ls4-perfo...maf-sucks.html
And I swapped
B and C PIN
from MAF sensor plug
when I plugged it, MAF sensor worked but the engine was shaking and coming down then it is gone off and showed the fault [P0622] .
if I unplugged it the engine will work fine but the MAF sensor fault P0102 come back and the fault P0622 will be gone also
at the attachment file will show when I plugged and unplugged MAF sensor
please in the attachment if there is any errors please fix it and send it back or show me where is the error .
