Results 1 to 3 of 3
Thread: Open loop table
    Sep 2017
    736
    Open loop table
    The open loop table in an 0411 pcm. Is this just a desired value the pcm looks at and adjusts from your VE table? How is this table "tuned"? Is that the point of open loop STFT?
    Thanks guys
    1997 30th SS. Torqhead 24x, TFS heads, 223/235 cam, 4l80e, S60 D1SC 14psi
    13,559
    The open loop Eq ratio?
    If you are talking that table, it's only job is to tell the computer what to command. So if it says 1.00, that is stoich and you are calibrating the VE or MAF table to achieve that. If you have STFT active in open loop, it will use the trims to try and reach maintain stoich.
    The table is normally richer at colder coolant temps as it's easier to run an engine with more fuel when cold and emissions reasons as well. Then it ramps it's way towards 1.00 as it warms up.
    Sep 2017
    736
    Yup you got it.
    I knew the answer just wanted clarification lol
