The open loop table in an 0411 pcm. Is this just a desired value the pcm looks at and adjusts from your VE table? How is this table "tuned"? Is that the point of open loop STFT?
Thanks guys
Thanks guys
The open loop Eq ratio?
If you are talking that table, it's only job is to tell the computer what to command. So if it says 1.00, that is stoich and you are calibrating the VE or MAF table to achieve that. If you have STFT active in open loop, it will use the trims to try and reach maintain stoich.
The table is normally richer at colder coolant temps as it's easier to run an engine with more fuel when cold and emissions reasons as well. Then it ramps it's way towards 1.00 as it warms up.
