Trying to dig up part number and sensor wiring diagrams with no luck so far. Anyone done this?
Factory Stock 97 SS M6 13.51 @ 104.3 mph
Stock Longblock LS1 w/ 233/238 P.S.I. Cam
10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
'99 TA trunk mounted 76mm 6 Liter
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
32psi and still winding out 5th on the highway somewhere
trying to find this also
I left the FPCM hooked up and adjusted the appropriate settings to use the power wire to the pump as a signal wire for relays. I am able to monitor the fuel pressure with everything still hooked up including factory fuel pressure sensor with no faults but this is with a return style system on a ZL1.
Enloe what settings did you change? seems ive just seen guys having to run a resistor on the trigger wire. I know when i tried to trigger my fore system with the wire coming off of the fpcm i had issues with the system throwing all of the stability track and locking down the ebrake. this is on a v2 but should be similar
AEM smart coil dwell.xlsxHere is my file. Use compare feature to see changes to include error reporting. You probably cant use these direct changes for your FPCM but you will get the general idea.
Greatly appreciated Enloe
03-29-19 AEM coils.hptSorry. I linked the wrong file. Here is the correct file.
