Results 1 to 16 of 16
Thread: Na BA to FG Turbo Map Help
    Ok so i have been looking around in the software for a while now and my BA ECU does not have any Map Sensor Calibration setting to change from 1bar to 2.5 bar fg map.
    What do i need to do?
    Do i need to load a tune in from a later model falcon that has map settings for me to change?
    This is the first na to turbo conversion and it is really doing my head in as everyone says that these fg maps are plug and play and it will not even run at all.
    Any help would be great.
    Feb 2013
    Logan QLD
    54
    It should be there under Airflow, General.
    Post up a copy of the file your working with. I've done a few NA to turbo ecu conversions BA & BF. I should be able to help you get it going. PM me if you want.
    I'd stick with your factory BA NA ECU file and just cut &paste everything from a BA turbo of a similar calibration.
    Wiring harnesses are different in BF & FG compared to BA. Thats prob why it won't go.
    Ok Luke111 i have added the file for you, I tried this before but i have not tried it with turbo logic enabled.
    Fg turbo map sensor has the same plug as ba/non turbo and apparently is meant to be a plug and play but my ecu does not show the map settings for some reason..
    Ok anyone reading this here is some info.
    Using FG Turbo map sensor- 0261230128 Direct plug in to NA BA cars, No wiring mod needed.
    Enable Turbo logic in the ecu and it works!! i now have boost.
    Feb 2013
    Logan QLD
    54
    I've never heard of the FG map sensor swap but that's handy to know!
    I cut the connector and resoldered the wires when I went from BA NA to BA turbo.
    I see you are running strategy HAAN9AW - and those extra parameters are not showing for your file.
    You could email HPTuners and ask them to add it for you.
    I have a BA XR6T II strategy I downloaded from the repository and it shows the map sensor settings. HAANFG4
    If you enable turbo logic, you shouldn't need to change the map sensor values with the 2.5bar.
    BAIIXR6TURBOBASE.hpt
    I'll check your file and make sure it looks ok for turbo. If I see anything wrong I will let you know....
    Feb 2013
    Logan QLD
    54
    OK I've had a look at your tune. I don't know where to start. Looks like its still mostly NA settings. It all looks really bad to be honest.
    This is my advice (take it with a grain of salt but it has worked for me).
    Get the last/best strategy Ford made for the BA XR6 Turbo. You can get a BA F6 Ute strategy from the repository. (Attached it for you)
    ba f6 ute.hpt
    You want to load up VCM Editor and load your file first the use the compare map to the BA F6 file. Then you want to cut/paste every single item you can see so they match. You can tell by looking at the colours of the buttons.
    This can be tricky sometimes. You need to cut/paste the axis as well. Sometime you need to go to many decimal places to get them to copy over so the buttons change to red. If they stay green it isn't identical between files.
    Its especially important to cut/paste all the transmission stuff over. It will help the transmission live.
    I could do this all for you but you won't learn anything if I do that.
    I noticed the breakpoint number you are using is wrong too. U need to fix that up. Also what you've done with the ignition timing isn't right. Just stick with the factory settings if its running on petrol. Keep all the correction tables original too. If you are running on E85 thats a different story. File name says stock injectors so I'd assume not.
    You need to upgrade the fuel pressure regulator too. The stock 2.8bar NA fuel reg with stock injectors won't keep up. The factory turbo 4 bar reg and injectors will only go to 8-9psi.
    Thanks Luke for looking into all of it
    I did notice that the breakpoint was wrong just before so i have rectified that.
    I have been playing around with the gearbox settings a bit and it is shifting really well, could be something to do with the diff gears 4.11 and car being lighter than a falcon (R33 Skyline).
    Definitely will look into the F6 Tune, I had another tune that had most XR6T settings in so maybe ill switch to that and enable Turbo Logic on that one.
    I have an aftermarket fuel regulator that is adjusted around 60psi and the injectors are showing they are maxed out on 8psi.
    I have tuned factory turbo ones and they usually run out of fuel around the 300rwhp mark depending on condition of the car.
    Might as well just start with the stock maps and modify to suit.
    Thanks for all your help I really appreciate it.
    May 2020
    BoostedPerformance did it run with Turbo Logic enabled?
    I was under the impression that the NA PCM does not have the wiring for the Boost Pressure Sensor located in the factory cooler pipes and therefore cannot use Turbo Logic and must use a separate boost controller
    Feb 2015
    Perth, Australia
    974
    They will run with turbo logic on. The map sensor needs to be a turbo one and the wiring needs to be correct. NA and turbo map sensors have opposite pin locations on the sensor. nA harness needs to have plug wiring reversed to work with a turbo map sensor.
    The boost sensor not being there can make idle and coast down challenging to get right, but it’s doable
    Nov 2009
    AUSTRALIA
    104
    Luke you can use an fg turbo map sensor as a straight plugin on the na wiring and no pins need to be moved.
    Feb 2015
    Perth, Australia
    974
    My mistake I must be thinking of BA/BF
    Aug 2018
    Mildura, VIC
    24
    You can turn off the boost sensor so you don't have the idle and coast issues.
    Jan 2021
    Hi there guys,
    I wanted to chime in and ask a question in relation to a project I am working on if you don't mind.
    I have a 2008 FG G6E that was originally an NA and was turbocharged by the previous owner.
    My question relates to boost control...
    As is was an NA, there is no factory boost control solenoid, hence they have managed this with an independent Turbosmart Eboost2 controller.
    My tuner would like to see about getting rid of the Eboost2 controller and controlling the boost via the PCM for greater control, such as boost per gear and more precise air/fuel ratio trimming I think was mentioned.
    Now with this in mind, would it be possible to just get a loom from a turbo wreak for instance, that has the boost control solenoid circuit and just replace my NA loom, or is the NA PCM different from that of a factory turbo PCM? I am just thinking that the NA PCM may not have the pins for that boost controller circuit, or it does and they're just not used in an NA setup. I don't mind changing the loom, but dread the thought of having to replace the entire PCM!😅
    Jan 2021
    Quote Originally Posted by JVK View Post
    Hi team, I have an 08 FG G6E NA which has been converted to a turbo. I bought it converted already.
    It's running the NA PCM still along with a Turbosmart Eboost2 boost controller. I'm looking to take it to the next level by running a Pirotta Flex fuel sensor kit. To use it though, I believe I need to do the full conversion to a Turbo PCM, I think I also need the loom containing the boost solenoid circuit for PCM boost control (can't see the plug there at the moment ) and the loom containing the MAP sensor circuit (can't see a connector for this either, which would normally be on the injector loom No.2). Got to have a look for the boost pressure sensors too, I believe these are part of the fog lights loom.
    Just want to make sure I am on the right track??? and if there are any wiring elements I may have missed in order to properly convert to what the Turbo spec should have. Ultimately the turbo PCM is going to be expecting sensors not used by the NA, just want to make sure they're all accounted for!!!😅👍
    I have a customers ba that's running complete stock turbo engine in na car, it's running on the na loom and ecu, copied all cells and axis across and the car drives great and that's all fine but the idle is terrible sounds like it's has a ghost cam tune, I've done as it says in this post and selected "not fitted to the boost sensor" but its still hunting at idle, what else is needed to be changed to correct this? Any help would be appreciated thanks. (Operating system is a HAAMFB2)
