Results 1 to 17 of 17
Thread: P0340 and delayed start after AFM delete kit - help please
    P0340 and delayed start after AFM delete kit - help please - solved!
    I'm a Ford specialist, so GM stuff is not my norm. Here at our shop, we've done two Texas Speed AFM/VVT delete kits, and both have had the same issue.
    Both trucks set a P0340 cam signal code, as soon as truck is started. Both trucks also have a delayed start on crank - about 4-5 seconds of cranking before the motor will fire. Fuel pressure has been checked and I see no issue there. To be honest, I do not know for sure that the delayed start is related to the AFM delete kit, but this is the customer's complaint.
    Both TSP delete kits come with a new timing cover, new cam sensor, and new jumper harness from the engine harness to the cam sensor. Both harnesses had the wrong plug end on them and did not match the cam sensor they include with the kit, which is the same sensor the truck originally had. I had to swap the plugs from the original harness over. I have verified that the wires are in the correct order in the plug.
    Checking crank and cam rpm signals with my Snap On scanner, I get no cam reading with the truck running. The truck runs perfectly fine, aside from the mentioned delayed start. I have checked the three wires to the cam sensor, both at the sensor and at the ECM. I have 5 volts on the ref feed, ground, and 1.9 volts return signal back to the ECM. As far as I can see, the ECM should be getting a cam reading.
    Does anyone have any ideas on either the P0340 code, and/or the delayed start?
    Any help would be greatly appreciated!
    Sal
    May 2015
    37
    What does the cam cover they included look like? I just chased through a similar problem and the cover they had sent was for a vvt engine, and the gear was a regular non vvt. the air gap is to much for the sensor to pick up. And caused the 340 code as well as delayed start.
    Quote Originally Posted by Tom @ Overdrive View Post
    Well, it doesn't have the big hump in it like the cover that came off. But I was suspecting air gap as well. But there's no way to adjust that.
    What has me confused is that I am getting a return voltage signal back to the PCM, but the scanner shows 0 cam rpms.
    Oct 2008
    297
    swap the outer 2 wires on the cam sensor harness
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
    Quote Originally Posted by camaro1 View Post
    Swap the reference wire and the return signal wire?
    Have you run into this before?
    Oct 2008
    297
    cam sensor on back of engine
    A=CMP SIGNAL
    B=GROUND
    C=VOLTAGE
    cam sensor on front cover
    A=VOLTAGE
    B=GROUND
    C=CMP SIGNAL
    gen 3:
    A=CMP SIGNAL
    B=GROUND
    C=VOLTAGE
    gen 4:
    A=VOLTAGE
    B=GROUND
    C=CMP SIGNAL
    This is a 2010 5.3 Silverado.... is that Gen 3 or Gen 4?
    Oct 2008
    297
    oh,, I would still verify the outer wires are correct at the cam sensor seeing that you had the connector apart
    Looking at the sensor on the motor, I have it wired Dark blue (5v) at the bottom, BRN (ground) in the middle, and Dark Blue/white (signal return) at the top of the sensor. The truck is a 2010.
    405
    2,357
    Are you sure you used a 4x cam gear.
    405
    2,357
    Look for A, B, C on sensor or connector
    I used whatever TSP sent me in the kit.
    I have that same pic on my Mitchell. Those wires are going to their corresponding letters, however the actual sensor pinout I found has B in the middle.
    405
    2,357
    Doesn't matter the orientation on the drawing as long as the correct color wire goes to the correct letter terminal. Did the cam gear look like B?
    Yeah, looks like B.
    What's got me confused, is that I have a return signal back to the PCM. I've got 1.9 volts on the signal return wire.
    I have done several dod delete used kit from summit .I always just plug engine harness in to cam sensor
    learning
    Thank you everyone. The issue WAS that the two outside wires needed to be swapped. This 2010 Silverado has to be wired in the Gen 4 pinout, even though Mitchell shows it with the Gen 3 pinout.
    Oct 2008
    297
    nice, seen that issue many times
