L86 swap hitting limp mode.
Hi guys,
I have done a few of these without any issue but it seems this one does not like to be ran on an engine dyno. Hitting 4000 rpm limit when we try to do a power run.
I did not ran into that issue before and I did a little bit of research online to realise the OS from a 2016 does not play nice in a swap without a TCM. I have the tranny setup to manual with the VSS turned off and all the associated DTC's checked out. Rev limits are also all to 6000.
Should I try just flashing a 14 OS or there is a way to make it run ?
Fuel pressure at the rail is good, pedal wiring is good to. No issue exept it won't rev past 4000.
Thanks guys.
Whats "Default Trans Limit" set to? ecm 12836
Forgot one rev limit table inside the trans default and all is good now !
