Results 1 to 6 of 6
Thread: NEW ECM VATS disable..still no start.
    Jun 2018
    42
    I got a new ECM from the dealer for 08 Zo6.
    The previous computer had a check sum error and would shut off after a few minutes.
    I was able to use another ECM and the car shut off was resolved.
    I disabled the VATS on the test computer from another car to confirm we needed another ECM.
    I now have a new ECM installed and disabled the VATS, but still not getting it to start. I am getting P0315 ckp not learned, but should still allow start up, P0633 immobilizer key not learned and P0602 Programming error.
    I am thinking of doing a OS overwrite using the tune from the previous computer.
    What are your thoughts?
    Dec 2014
    2
    I’m having the same problem with a e-38 it will start run 5 seconds and shut down watching to see what they say about yours
    After setting VATS to disable and all Theft deterrent codes to "No error reported" perform a "Write Entire". "Write Calibration" will not disable VATS.
    Nov 2009
    All Around
    3,149
    yes as mentioned disable vats and no error report and must do a write entire. should get fuel and spark
    Feb 2022
    12
    This is what I needed to read had the same issue Friday at work tuner finally said write entire and try again it started. Was wondering if I would still have issues but looks like it's the fixed unless I need to relearn key again with my new ECM. Thanks
    "Immobilizer Key Not Programmed – ECM
    2010 2SS/RS/ Mods, Whipple, 1000cc injector, 102MM TB, Innovation West 10% OD pulley set up 8 rib, AGP twin 450 fuel system w flex on E85, CAI K&N, LT with OR Cats aka no catalytic converters, Coils and wires, 3" exhaust with mufflers, Oil catch can, 2015 ZL1 9.9 3.23 ratio, BMR upper Lower control arms, 15"conversion, BMR Anti Roll Bar 315/60/15 ET street slicks
