Results 1 to 5 of 5
Thread: Wideband Hookup?
    Wideband Hookup?
    So I just got a new AEM wideband sensor/gauge setup I got it in the car but I'm not really sure how to connect it io my MVPI Pro...... ....... Any help anyone can give would be greatly appreciated.
    May 2005
    Conway, AR
    347
    White wire to pin #1, black to pin #5, red is 12v power source, prefereably switched if you are leaving it in the car. Mine is portable so I got an adapter for the cig lighter at radio shack. Has a ground and power terminal.
    Chris
    2009 Silverado Crew Cab 5.3L, stock.
    ok thanks... and just to make sure the pins are from bottom to to? oh yea will it still work if i don't hook the black to the MVPI?
    May 2005
    Conway, AR
    347
    Pins are top to bottom. And the black ground either goes to the mpvi pro or a clean ground. The obdII port uses the pcm as a ground, thats why I ground it there.
    Got it thanks....
