Originally Posted by
Robert00MustangTurbo
Hello,
I have a 2011 GT500 on the dyno with:
VMP Twin 67MM Throttle body
Whipple 2.9L w/2.8750 pulley
Innovators West 10% overdrive Crank Dampner
ARH Long Tube Headers
Fore Innovations Return fuel system with twin walbro 465
ID1050x Injectors
E85
EGR Deleted
18 PSI Boost
The complaint from the customer is that his throttle sticks after he completes the wide open throttle run and the car will stick at near redline and continue to pull, Causing the customer to shut the car completely off and restart the car
I verified this on the first dyno pull and the throttle body will stick at 15 degrees and around 5600RPMS after the WOT dyno pull and stay around there continuously.
I have tried multiple throttle body maps and issue repeats, driver demand and torque tables, no changes.
I do have a clue that the problem started when the 10% overdrive dampener was installed and was previously pushing 14-15 pounds of boost before it was installed.
Is there something I'm missing that needs to be done in the torque tables or speed density tables, or others that needs to be changed?
Thank You in advance
