I have the MPVI2, Just installed a new throttle body on a 2011 traverse 3.6 litre. Will the VCM or scanner give me the ability to put the vehicle in "idle relearn" mode?
If its a feature that is available it would be in the scanners vcm controls section, check it out, if its there and clickable it means its available.
special functions tab?
Not there.
Crap
You do not need to license a vehicle in order to use the scanner.
