I am working a file and have a question. When the engine is ECT is cold and I put truck in reverse, it cuts off. Once warm I don't have that issue.
Non VVT cam installed with stall to match the cam.
Tune is attached.
Tune is attached.
i see a few tables that still have stock values.Originally Posted by [email protected]
--idle external load table. engine-idle-torque-external load
when the ecu doesnt see throttle input it refers to this table to model the idle torque and external loads to the engine. the values are units of desired torque. do not mess with any negative numbers in this table. try adding 50 rpm to any value from 450-1100 in all temp ranges.
--limit offset. engine-idle-torque-limit off set
try raising this value to 100 ft lbs. dont go to high or your idle will oscillate.
