Results 1 to 5 of 5
Thread: Changing the speedo on a 2012 2500?
    Tuner in Training BluBeaSSt's Avatar
    Dec 2011
    48
    So this truck is confusing me, unlike the GM maps there is no tire change table. Do you use the VSS? Can't use the scanner like my Jeep either. Any help would be great!
    2002 Camaro SS
    2013 Jeep JK 2 Door
    Dec 2018
    Fortuna, California
    19
    If you changed tire size, you want to change the "VSS Tire Revs per"
    Dec 2011
    48
    Quote Originally Posted by Wgluv2hunt View Post
    Is there a calculation for that?
    2002 Camaro SS
    2013 Jeep JK 2 Door
    Dec 2018
    Fortuna, California
    19
    You can lookup how many revs per mile your tire size should be. You will need to make minor adjustments to get it exact.
    Changing the VSS does not correct the speedometer though. I'm not sure what the VSS does...
    2019 CCSB Bighorn - Excited HP Tuners finally supported Cummins CM2350&2450 platforms
