Results 1 to 4 of 4
Thread: Dyno Tune & Sport Mode? 2013 Charger R/T. Compatability? Conflict? Risk?
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    530
    I had my 2013 Charger R/T Plus dyno tuned a couple years ago using my credits via HPT.
    I recently enabled Sport Mode and there is definitely a difference in how they run with Sport Mode being more aggressive.
    Is there anything at risk?
    Is there a way to pull both tunes or modes separately and do a compare?
    I can do WOT or hard run scans and compare but I don't want to max it out until I get answers.
    I wonder if the Sport Mode is more aggressive than it would normally because of the Dyno Tune?
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Feb 2019
    38
    The sport mode is going to be part of your tune in the transmission section most likely. If you got a dyno tune I would assume they would tune everything including sport mode. You should ask the shop if the tuned sport mode or not.
    Advanced Tuner Blue Bee's Avatar
    Mar 2017
    DFW
    330
    all sport mode does is switch driver demand (throttle sensitivity) tables and trans pressure/shift points. So to clear up your concern, there is no fueling or timing changes, so you won't hurt the engine no matter the mode it was tuned in.
    Jun 2009
    N. GA
    530
    That's good news thanks. Thanks both of you.
