Results 1 to 10 of 10
Thread: Tuning VVE with wideband help
    Dec 2018
    South Florida
    31
    Hi all,
    Can I get verification that I'm headed in the right direction with regards to tuning my virtual VE table with my aem wideband?
    I couldn't get anything to log when doing the AFR Err method, but I realized that EQ Err was what I should of been looking for. Anyways, here are the tune and log files if you could give it a look-see and let me know if there are any changes that I need to make before heading off into the abyss.
    I didn't attempt to go for a drive or anything, just sitting in the driveway making sure a log was being generated before I dive into vve calibration.
    Thank you in advance!!
    Jun 2010
    293
    Did you remove one of the front O2s? B1S1?, i would recommend to keep it and put another boss for the WB, i like to do idle, light load part throttle with o2s trims, and WB for mid/high loads, WOT.
    Before you start to log, turn off/reset STFT,LTFT with special functions. i always do it just in case.
    Dec 2018
    South Florida
    31
    I did remove the factory O2 for this. I’ve done the MAF & VVE with the LTFT & STFT math already. I was wanting to see how far off or how much better i could do with the WB.
    I disable long and short term fuel trims via the tune and also reset and disable the learning in the scanner before i log.
    Am I on the right track?
    I did a log this morning and my vve is looking much smoother.
    Jun 2010
    293
    yes you are.post new log file.
    Dec 2018
    South Florida
    31
    It won't let me upload for some reason..?
    Dec 2018
    South Florida
    31
    Tried to upload again but, it's a no-go. They must be having problems with the site..?
    Edit** Figured it out. My log file exceeds the upload limit. Lol!! It's 11Mb.
    Apr 2016
    331
    You can save a section of the log instead of the whole thing. Without hp in front of me, you zoom in on a section and save that only.
    Dec 2018
    South Florida
    31
    Quote Originally Posted by NotSure View Post
    Could you elaborate on the "zoom in on a section" part? I'm not that technically advanced yet. Lol!
    Apr 2016
    331
    Use the + and - magnifying glass icons to get your desired segment of the log in the "window" at the bottom of the page. Zoom in on the relevant size and then you can drag the "window" to cover the area in question. See picture.
    Then go to top left dropdown and select "Log File", then "Export Log File". This will open another window where you can select Output Format of either "HP Tuners" (select this) or "Comma Separated Text". Below that you can select Data Range of either "Entire Log" or "Visible Range"(select this). Sorry my surface pro doesn't seem to have a "print screen" function where I could capture these steps in picture format.
    Update to add this pic for the above step.
    Dec 2018
    South Florida
    31
    Thanks for that NotSure! I’ll give it a go and post what I get.
