Results 1 to 18 of 18
Thread: Challenger Hellcat M6 - torque management
    Sep 2018
    28
    Hey everyone, does disabling the manual transmission in the trans tab disable trans related torque limiters? Any issues with doing this? Benefits?
    Sep 2018
    28
    Would really appreciate the input
    815
    I don't think that does anything.
    All of the torque management is on the engine side for a M6 AFAIK. The trans is "dumb".
    I know when trans is disabled, every time you depress the clutch the RPMs jump up which is annoying.
    Mar 2018
    Illinois
    873
    Quote Originally Posted by orrwhat View Post
    Have you ever tried to log what is commanding the jump in throttle? I thought the clutch switch was not an input read by the PCM?
    Sep 2018
    28
    it makes a huge difference. diabled, idle hangs / flares on roll to a stop. Also, fans run all the time on high and override your settings. I just wanted to see if there was any negative impact to turning it on. Also, expected tq is usually around 44 at idle with manual trans disabled. Enabled, expected tq is 0. How would this impact idle?
    Sep 2018
    28
    yep.
    Sep 2018
    28
    Quote Originally Posted by Homer View Post
    yep, they do.
    Mar 2018
    Illinois
    873
    Quote Originally Posted by Ztuned View Post
    yep, they do.
    Thanks, just checked the PCM connections and sure enough...there is a clutch switch input.
    Sep 2018
    28
    anyone everfind out if enabling or disabling it impacts a tune any besides driveability/ idle ?
    Can you post a stock tune for this car?
    Sep 2018
    28
    Bump. I just want to know if it somehow overrides the throttle torque request source
    Sep 2018
    28
    Must be some "super secret" that no one wants to share.... because i do see driver demand tq & expected / actual differences with the trans enabled and disabled...
    Feb 2019
    38
    Torque management limits tge torques for each gear. Raising them above your expected torques level is better then disabling fro. What I have read and understand. They say without it shifting gets sloppy. My torque management had different torques levels for different areas so i raised the max torque area by 100 lb ft and raised the lower torques for prime gears anywhere from 50 -75. Granted im driving a ram and still cant find info on my trans. I would raise the limits and see how it feels. Disable amd see how it feels and go from there.
    Sep 2018
    28
    i'm thinking it's either the only way, or the easiest way to turn off engine side TCM
    Aug 2020
    Somewhere hot in Arizona
    52
    any update on how this testing went?
    My ride.. 2009 Limited SRT8, Brilliant Black ⚫, Centerforce Clutch RIPx2 now Ram Clutches!, Full Adjustable BMR suspension, Solid mounted Cradle and Diff, DSS 1PC DS, Level 5 Axles, Belanger Headers, AFR500V2, Lowered, 180 Tstat, RonDavis Rad, Staggered tires.
