Results 1 to 13 of 13
Thread: ridiculous Rich at idle, No changes editing tables...
    Apr 2016
    30
    Hello to All
    I'm Raul from Spain, I have a customer with a Corvette C6 (LS7) with high Cams and high compression piston. This customer send to US (yes the car, not the engine) to be tuned. THis tuner did the engine and the tune file. when the car returned, idle was around 11.8 AFR and 1000 rpm to have a stable idle. Too Rich i think, i saw cars like this with 13.5 or 14 AFR idle
    4 month ago the idle went to 10.1 without any reason, this customer checked everything on the car, changing lambda sensors, cats and the idle still is there. he called me this week to check the car with HP tuners and see if something is wrong. I was all the afternoon checking and modifing tables but nothing changed. here you have the things i did:
    -Move the ECU to open loop.
    -edit MAF table, i moved to stupid values to see any change?( from 17 g/s to 4g/s)
    -edit VE table, same as maf (from 60 to 10)
    -edit MAF table at Cranking, nothing
    -edit lambda demand (14.7)
    -edit lambda table rich/lean voltajes
    Maf values are ok, if i change the table i can see the same frecuency gets me different g/s. Map sensor Works correctly too. Checked with engine stopped and reads atmosferic pressure, with engine started, reads about 65 kpa
    if i put the car in closed loop, i can see the short and long trim go to 10.1, and are near to 0% correction at this value, if i modify the Maf table, closed loop (long and short trims) starts to add fuel to go again to 10.1. Car has some DTC deleted like, lambda, Throttle, AC, Air pump etc, like a race car.
    For me the car looks like it is in limp mode and goes to a very rich escenario for safety. Not sure if could be posible with this ecu.
    Any idea about this?
    Aug 2014
    Central, LA
    737
    Got any logs you can share? What do the o2 voltages look like?
    Apr 2016
    30
    sorry, i did not have any log saved, but o2 voltages were around 0.6 volts...
    Nov 2009
    All Around
    3,149
    is the injectors changed? which brand
    Apr 2016
    30
    No, injectors are stock.
    Minimum injector pulse is 1.2 ms and I have between 2,8 / 3.2 all time
    Nov 2009
    All Around
    3,149
    post tune and mods
    Mar 2019
    4
    Quote Originally Posted by SultanHassanMasTuning View Post
    post tune and mods
    Thank you SultanHassan for your quick and nice response!
    I am the car owner, the car is a c5 z06, as Raul said it was sent to US and was prepared and tuned there. Raul will post you the tune file (HPtuners). As you can see injectors are not stock, it is my fault I said Raul stock but I was wrong.
    Mods are as follows:
    - LS7 427 CID
    - Nick Williams 102 mm throttle body
    - FAST 102 Intake Manifold
    - CNC porting & polishing of cylinder heads
    - multi-angle valve job & surfacing for 11.5:1 compression
    - high performance dual valve springs, titanium retainers & valve locks
    - GT21 camshaft by Competition Cams . here you are the link to the cam specs: https://www.lingenfelter.com/PDFdown...L210146006.pdf
    - Haltech air intake
    - FIC 660cc 72 lbs hour fuel injectors
    - 160 degree thermostat
    - GM Head gaskets & head bolts
    - LG Long Tube Headers & high flow catalysts
    Please, if you need further info about mods do not hesitate asking for them.
    Thank you very much in advance!
    Carlos
    Apr 2016
    30
    Here you have?.
    Apr 2018
    29
    First thing I notice is your engine size is incorrect in the tune file it should be .875 for a 7.0l ls7, Second thing I see is your minimum injector pulse is @ 1.261 which seems pretty high to me. Correct and double check all your injector data and try again.
    13,581
    Yup, that injector data stills says 42ish lb/hr injectors and not the 72lb/hr FIC injectors listed above.
    Mar 2019
    4
    Thank you for your response, I?ll talk to my local tuner
    Mar 2019
    4
    Quote Originally Posted by Jwilliams View Post
    Thank you for your answer Jwilliams, I?ll talk to my local tuner
    Mar 2019
    4
    Thank you 5FDP, we are still double checking physically the inyectors size. LPE point out in this package the 72 LB/HR FIC but as you said 42 is in the tune.
    We?ll let you know
    Thank you again
