Results 1 to 8 of 8
Thread: E92 ECM - cant get fans to turn on.
    Having issues getting my fans to turn on. Even with the VCM Scanner I cant command the fans to turn on. Any suggestions? Posted my tune file below.
    THANKS
    2015 E92 NO FAN ISSUE.hpt
    May 2003
    South FL
    1,366
    Have you ruled out a mechanical issue such as a blown fuse, relay or fan motor?
    [email protected]
    Owner/GM Calibrator
    Checked the fuse which was good. Switched the relays with new ones still not working. Doesn't seem that the ECM is grounding the trigger wires when I try to command them on with the scanner.
    May 2003
    South FL
    1,366
    If the scanner won't make them come on, then I wouldn't think the issue is not with the tune, but rather a mechanical or electrical issue.
    [email protected]
    Owner/GM Calibrator
    On gen v the fans are PWM. Most of the time hptuners wont be able to control the fan in the scanner. Sometimes it does work on the 5.3 OS. Are you trying to drive a relay?
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    134
    You have the fan type selected for discreet. This should be PWM EV I believe, atleast my 6gen is that way.
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
    Oct 2017
    45
    Dont think anyone's gotten the e92 ecu to control relays. The gm gen 5 swap kit has a calibration that uses the relays.. if you could find the calibration file and try it. Fan control works on my swap with vcm controls (pwm)
    Usually the 5.3 os will let control speed via the scanner. The 6.2 OS doesn’t allow the scanner to control speed. I have seen guys set the pwm freq to 1200 hertz to make a relay stay latched.
