Results 1 to 6 of 6
Thread: MPVI2 Expander Hub
    Mar 2019
    Cookeville,TN
    3
    MPVI2 Expander Hub
    ok i have a question about the MPVI2 Pro feature set. I just bought it on HPtuners website and it shows the MPVI2 OBD2 connector, the pro software, the pro link, and the expander hub. The expander hub hasnt been released yet so my question is will i get shipped one when it does get released since i bought the pro feature or will it only ship to those who buy the pro feature after its released?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,260
    No the expander hub is an additional cost, I believe its still TBD.
    Mar 2019
    Cookeville,TN
    3
    ok i didn't know it seems kinda misleading that it shows it with the pro feature set
    HP Tuners Support
    (foff667)
    28,260
    Quote Originally Posted by DYSTBLackTruck View Post
    Lets hope not, it clearly says it in the text https://forum.hptuners.com/showthrea...ure-Set-Update
    Expander Hub
    The Expander Hub is expected to be released in Q1 of 2019.
    The Expander Hub will offer a wider variety of inputs and analog outputs, and the capability of
    Bluetooth pairing with the MPVI2.
    It will be the ultimate tool for the professional tuner that will help you perfect your calibration by
    integrating any device you need to use.
    Expander Hub
    • 2x dedicated 0-5V analog outputs
    • 4x universal pins capable of analog input, digital input, PWM input, digital output, or PWM output
    • 2x external CAN bus inputs
    • 100 Hz analog signal acquisition rate
    • Configurable and field updatable via HPTnet (wired mini display port)
    • Configuration data is non-volatile (remembers its settings)
    • HPTnet via Bluetooth pairing to MPVI2 enabled
    This device will be an additional charge (TBD), and will need to be purchased separately
    from the Pro Feature Set
    Mar 2019
    Cookeville,TN
    3
    Screenshot (2).png this is why im confused because it clearly shows the expander hub with the pro feature set. hopefully the photo uploads
    HP Tuners Support
    (foff667)
    28,260
    Sorry to hear you are confused but I will reiterate the expander hub is not free, nor is it currently available, nor does it come free with the pro feature set.
